Request a Working Definition of Specific Queue Drops
jhaverkos
We are presently trying to identify how well our 3750 QoS policies are working. The following drop indicators were found using the command: 'show controllers ethernet-controllers port-asic statistic'. Looking for an explanation of what is happening in the switch to cause these drops.
1082 RxBuffer Drop DestIndex
5755781 SneakQueue Drop
aghaznavi
Level 5
Level 5
This drop is may be due to some exceptions on the receive side. Use "show platform port-asic exception" command and see if any of the receive side exceptions are incrementing
Using the command 'sho platform port-asic exception' seems to yield indexes into a table. Do you know how to use this information to get actual error counts?
Also, do you know what a 'SneakQueue' is and how/when it is used in moving packets through a 3750?
