Request support for ATA 187 configuration
Hi All ,
I got a new cisco ATA 187 and trying to register with the 3900 Voice Gateway router - CME.
But it was unsuccessfull. Can some one help on the same ?
Steps undergone from my side :-
1. Updated the firmware from the cisco website for ATA 187 - Completed.
Configuration : -
2.
voice register global
mode cme
source-address x.x.x.x port 5060
max-dn 32
max-pool 10
authenticate register
authenticate realm all
voice register pool  1
id mac xxxx.xxxx.xxxx
session-transport tcp
type ATA-187
number 1 1xxx
number 2 1xxx
preference 1
username ata187 password cisco
codec g711ulaw
3.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  registrar server
4. Ephone and Ephone configuration :
ephone-dn  30
number 1399
name Fax
ephone  30
mac-address DCA5.F486.5125
max-calls-per-button 2
type ata
no dnd feature-ring
button  1:30
Pls suggest accordingly , Thanks in advance .
Hung Wen Cheng
ATA-187 only support sip
maybe you need try setting:
mode cme
source-address X.X.X.X port 5060
max-dn 20
max-pool 10
hold-alert
tftp-path flash:
create profile
voice register dn  1
number 1XXX
label Fax
name Fax
registration-timer max 720 min 660
id mac 1111.2222.3333
type ATA-187
number 1 dn 1
dtmf-relay rtp-nte sip-kpml sip-notify
DN = ephone dn
POOL = ephone
