Requesting Basics of Plus DIaling
I've inherited a working VoIP configuration for a growing business, and I haven't been able to keep up with all of the things that are going on.  One such new request is to incorporate + dialing across the board.
The end result should look something like this. I'm sure I'm manging some piece of this in my explanation
Type of Users:
User A - A user in the US office, who has a 4-digit extension, on a Cisco VoIP device
User B - A user in the US office, who has a 4-digit extension, on a Cisco VoIP device
User C - A user in the US who works out of their home, and does not have a Cisco phone
User D - A user in Eurpoe, who uses a Non-Cisco VoIP solution.  No SIP
User A and User B are in the USA. We are running CUCM 8.6.2(SU2), Unity 8.6.2, and a couple of Voice Gateways (2821s runnng 15.1(3).  Our connection to the PSTN is via FXO and BRI - no SIP.
US Numbers are supposed to be stored in (NPA) NXX-XXXX format.  European number are currently stored includingthe country code. We'll probably by formalizing the format for everything to E.164.  An upgrade to CUCM 9.0 or higher is likely (mainly for Jabber support, CUPC, etc)
All users' Active directory record are be be updated to include a + sign.  If User B looks up User A in their phone's Corporate Directory, the 10 digit telephone number for User A is displayed with a + prefix.  If User B then wishes to call User A, they hit the Dial key on the phone, and the phone dials the 4 digit extension.
if User B wishes to call User C, it would dial 9, followed by 1, followed by the ten-digit telephone number that is listed in the directory.
If User B wishes to call User D in Europe, the phone would dial 9, followed by 011, followed by the telephone number in the directory.
We have the Active directory piece working, and the phones display the +.  However, if we attempt to dial, the call cannot be completed as dialed.
Obviously something somewhere need to change, but I don't know where to start looking.  My guess would be Call Manager, but I'm not that familiar with all of the intricacies yet.
Is there some kind of tutorial/guide on setting this up?  In th future, users in foreign ofices will likely have Cisco VoIP, and we'll want to incorporate 4-digit dialing to these offices as well.  As solution I come up with should be able to get wrapped up into that requirement.
Thanks in advance!
1 REPLY
VIP Super Bronze
You will need to configure tranlsation patterns to strip off the + and any other digit that has been prefixed..
eg if you have +557000 and your user extension is 7000
Then you need to confiure a xlation pattern like
pattern:\+55XXXX
called part transformation mask: XXXX
You need to assign the correct CSS to the xlation pattern
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
122
