??? your question was about call forwarding
that parameter only works when you take a call from the PSTN, press transfer, dial another PSTN number and try to transfer the call
if it's, i'm glad it helps, but please then properly describe the issue or what you want when you post. forward by any means is the same to transfer
java
if this helps, please rate
java
www.cisco.com/go/pdi
