03-26-2007 02:45 PM - edited 03-14-2019 08:41 PM
I am trying to translate an incoming fax call and reroute it back out to the PSTN to another Fax number is this possible ?
I am translating the incoming number into another number, and have a dialpeer matching that number pointing back out the PSTN, but with no success so far, just getting busy tone when calling in.
Would appreciate links to references/examples.
Thanks in advance
03-26-2007 03:03 PM
How the call is coming in ? do you have did ? if did is working with ephones you can configure CFA on one of these, no need to translate.
03-26-2007 07:40 PM
This should work. Are you able to call the translated number from the CME phones? Please paste your configs.
Anup
