Community Member
Reroute a call back out to the PTSN - CME
I am trying to translate an incoming fax call and reroute it back out to the PSTN to another Fax number is this possible ?
I am translating the incoming number into another number, and have a dialpeer matching that number pointing back out the PSTN, but with no success so far, just getting busy tone when calling in.
Would appreciate links to references/examples.
Thanks in advance
Hall of Fame Super Gold
Re: Reroute a call back out to the PTSN - CME
How the call is coming in ? do you have did ? if did is working with ephones you can configure CFA on one of these, no need to translate.
Silver
This should work. Are you able to call the translated number from the CME phones? Please paste your configs.
Anup
125
