Community Member
Reserve external lines
At the moment we are having a huge amount of calls to the office and this is taking up all our external lines.
I was wondering if it would be possible in call manager to reserve a few lines so people can still make external calls.
Any help would be much appreciated
1 REPLY
Re: Reserve external lines
Sure, you can do that. You will need to configure your gateway and your dial peers/dial plan appropriately - along with the incoming dialed #s hunt group (if there is one).
-brad
http://www.ccbootcamp.com
(please rate the post if this helps!)
105
