Reset Cisco IP phone in branch office
I have remote side and I need to do factory reset to the phones there. How can i do remote factory reset on those phones without going there and do it manually?
1 ACCEPTED SOLUTION
Well, you're out of luck,
Well, you're out of luck, what you're looking for is available in 10.x, but not previous versions, you can wipe and reset phones in bulk. You would need to find a 3rd party app that lets you connect directly to each phone and issue the necessary key presses to do that.
java
if this helps, please rate
www.cisco.com/go/pdi
You need to mention what call
You need to mention what call control agent, and version, you're using, not just what you want to do.
java
ohh, sorry. I have cucm 8.6
ohh, sorry.
I have cucm 8.6 in centeral location with three sides. Now I have new server with new cucm 10.5 i want to move all phones from cucm 8.6 to 10.5 and keep cucm 8.6 for lab test. All phones in remote side still registered with cucm 8.6. I have changed dhcp tftp option 150 and reset the phone by shutdown the switch port.
java
As Jaime mensions you may
As Jaime mensions you may want to look at a 3rd Party application to send keypresses in bulk to IP Phones.
I suggest you have a look at PhoneView from UnifiedFX, it is a full endpoint management product that can interact with IP phones remotely in bulk.
Also, PhoneView recently passed Cisco IVT testing, which means PhoneView is now the  only Cisco Compatible 3rd Party product for endpoint management.
This video provides an short introduction to PhoneView
http://youtu.be/HYwhKw7UAMY
Kind Regards.
Stephen Welsh
CTO
http://www.unifiedfx.com
Yes Stephen. I have used and
Yes Stephen. I have used and it's very good 3rd party application.
Muaaz
Hi.What I've done in the past
Hi.
What I've done in the past for this situation is to create a new dhcp scope with another subnet and create a new VLAN.
Than placed remote ip phones in the newly created VLAN.
Try it and let me know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo, I have tried this
Hi Carlo,
I have tried this way with shutdown the port and no shutdown, but it didn't worked I had to unplug/plug the cable then after while the phone got registered with new CUCM
Thanks Carlo
Muaaz
236
