Silver
reset Directories URL
Hi experts
in 7945 IP phone under settings/device configuration/http configuration there is this Directories URL link.
if i change this link in the server it will not change in the IP phone even if i restart it.
i found a solution to do that by resetting the phone to its factory default or by deleting some file uder Trust list.
however i am looking for a centralized solution and not a phone by phone (manual) solution. is it possible ?
thanks.
1 REPLY
So looks like you are talking
So looks like you are talking about the Secure Directory URL, correct?
While I am not 100 percent sure off the top of my head why a reset would not change the URL for you, I can provide with you an answer to your question about deleting ITL and or CTL files in bulk.
VoIP Integration make a product for exactly this.
https://www.voipintegration.com/Software/Bulk-CTL-Eraser/
35
