Community Member
Reset overhead paging (E&M) port - H323 Gateway
We have a problem where people are forwarding calls to the overhead pager through paging speed dial. Since this number only exists on the H323 gateway and is not a line, the user has no way of clearing the call or retrieving it. How can we set the E&M port to automatically drop the call after 1 minute (or so)? Or, if anyone has a better suggestion, I'm open.
1 REPLY
Re: Reset overhead paging (E&M) port - H323 Gateway
Without doing scripting I don't think you'll be able to automatically disconnect a call after 1 minute.
You can clear it manually with this command:
nicmatth-sip#clear call voice cause 16 id ?
<1-FFFF> call identifier as shown in brief format
Use 'show call active voice brief' to get the call id.
You could incorporate this into a router kron job with a script if you got fancy.
hth,
nick
275
