Reset phone preferences
Is there a way to reset all phone preferences (e.g. ringer volume, etc) back to defaults ?
I'm using CUCM 6.1.3 with 7911/7941/7961 handsets.
GTG
Please rate all helpful posts.
Re: Reset phone preferences
Reset to factory defaults is the only way
java
if this helps, please rate
java
www.cisco.com/go/pdi
You mean there's no way to do it remotely, say, via CCMAdmin ? That's a bit pants :-(
Only with 3rd party apps like this one
Phone Remote.
http://www.voipintegration.com/software.html
But CUCM has no means to configure user specific preferences like those ones
java
java
287
