Community Member
Reset Service-Module Password
Customer has a 3825 with an NM-CUE-EC
The CUE came with 2.1.3 version
Router#service-module service-Engine 1/0 status
Service Module is Cisco Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is in Steady state
Getting status from the Service Module, please wait..
cisco service engine 2.1.3
Is there a way to reset the password so I can login via the cli.
I tried "service-module service-Engine 1/0 password-reset" reloaded the module, but I am still not able to access it.
Community Member
Re: Reset Service-Module Password
Community Member
Does anyone have another solution for this problem? I also need to reset the password on the a aim-cue service engine and cannot. The link provided does not help.
Are you sure it isn't the routers password your being prompted with? When you session into the CUE from the router it uses a line interface and the router may be doing the asking, it may not be the CUE asking.
If you have 'aaa new-model' in your config, try briefly removing it (no aaa new-model) and make sure the line configuration has no login or password under it also.
Erick
Community Member
Thanks, This solved my problem.
I found that the service module does not have its own username / password, nor does it have an enable password. Even though I was consoled in and in enable mode it still asked me to authenticate with a ROUTER username / password.
I must have fat fingered my standard password during one of the automated setup scripts.
Good to hear.
On the router config, it looks like it be line 66 from the output you posted.
So, it should look like this:
line 66
login
password
on the router config, you may want to reconfigure that line setup.
4892
