Reset UCCX 9 Platform / OS Admin password
Hi Everyone,
We are trying to reset the OS admin/Platform password for UCCX Version: 9.0.2.10000-71 on a Sub.
Will appreciate any suggestions/methods which can be used - without having to reboot the cluster or the pub.
  • IP Telephony
Have you seen this? No reboot
Have you seen this? No reboot required.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/9_1_1/CUCM_BK_C6AE17AA_00_cucm-cli-reference-guide-91/CUCM_BK_C6AE17AA_00_cucm-cli-reference-guide-91_chapter_0110.html#CUCM_CL_SB2BA64F_00
Anthony Holloway Please use the star ratings to help drive great content to the top of searches.
Hi Mavinktul,This process
Hi Mavinktul,
This process should be the same as resetting the administrator password on the CUCM.
username: pwrecovery
password: pwreset
It will then check if you have physical access to the server/VM by asking you to load and remove a disc. Any disc/iso image can be used for this.
Hi,I am following the same
I am following the same procedure and at the end got message "the password has been reset" but when i am going to login it still give same incorrect login error.Please help.
371
