10-30-2010 10:32 AM - edited 03-16-2019 01:38 AM
I have unity connection 7.1.3, i can't login to cisco unity connection administration account its say account has been locked,i tried all the step's provided by cisco support community its not working and also i tried to reset from CLI command also its not working.
Any help in this issues.
Ali Nasser
Solved! Go to Solution.
10-31-2010 05:59 AM
Hi Ali,
Did you follow the steps outlined in this doc?
Cheers!
Rob
10-31-2010 05:59 AM
Hi Ali,
Cheers!
Rob
11-01-2010 02:20 PM
Hi rob,
Thanks for your reply the issuse has been solved.
Ali Nasser
11-02-2010 05:38 AM
Hi Ali,
Great work my friend! Glad to be of some small help here
Cheers!
Rob
