Resetting efxs ports?
Customers got CME and what appears to be a hung virtual voice-port…. As you can see from the ephone debug below they've got a 7941 with 2 lines, both receive calls fine but when they try to seize the main DN it doesn't get dial tone and won't call out whereas the second line does…. Prior to running this debug I got them to swap the phone out so it's deffo a fault on the DN, the main problem I've got is accessing the individual port “voice-port 50/0/3.1” won't take even tho the IOS command help suggests it does! As a nearly last resort I reset the main voice-port but even that hasn't cleared the fault! Strange.. anyone know how to reset this on it's own before I think about rebooting the CME!
The debug simply shows both lines being seized….. and there are no live calls on the system to match this!
Dead Outgoing Line (602)
Elizabethan-CCME#
Jan 24 08:55:58.460: ephone-59[24]:SkinnyRestartTransferCollect for line 0 chan
Jan 24 08:55:58.460: ephone-59[24]:SkinnyRestartTransferCollect ignored
Jan 24 08:55:58.460: ephone-59[24]:SpeakerPhoneOffHook
Jan 24 08:55:58.460: ephone-59[24]:OFFHOOK
Jan 24 08:55:58.460: ephone-59[24]:---SkinnySyncPhoneDnOverlays has activeLine
current DN 3
Jan 24 08:55:58.460: ephone-59[24]:SIEZE on activeLine 1 activeChan 1
Jan 24 08:55:58.464: ephone-59[24]:SetCallState line 1 DN 3(-1) chan 1 ref 3380
TsOffHook
Jan 24 08:55:58.464: ephone-59[24]:Check Plar Number
Jan 24 08:55:58.464: efxs_onhook_offhook: call is already reserved on htsp 50/0/3.1 cdb 0x0
Jan 24 08:56:23.476: %ISDN-6-DISCONNECT: Interface Serial0/0/0:1 disconnected
rom 7791752722 , call lasted 265 seconds
working line 2 (601)
Elizabethan-CCME#term mon
Elizabethan-CCME#
Jan 24 08:55:33.100: %ISDN-6-DISCONNECT: Interface Serial0/0/0:3 disconnected f
rom 1777869503 , call lasted 76 seconds
Jan 24 08:55:36.872: ephone-59[24]:SkinnyRestartTransferCollect for line 0 chan
Jan 24 08:55:36.872: ephone-59[24]:SkinnyRestartTransferCollect ignored
Jan 24 08:55:36.876: ephone-59[24]:SpeakerPhoneOffHook
Jan 24 08:55:36.876: ephone-59[24]:OFFHOOK
Jan 24 08:55:36.876: ephone-59[24]:---SkinnySyncPhoneDnOverlays has activeLine 2
current DN 2
Jan 24 08:55:36.876: ephone-59[24]:SIEZE on activeLine 2 activeChan 1
Jan 24 08:55:36.876: ephone-59[24]:SetCallState line 2 DN 2(-1) chan 1 ref 33801
TsOffHook
Jan 24 08:55:36.876: ephone-59[24]:Check Plar Number
Jan 24 08:55:36.880: DN 2 chan 1 Voice_Mode
Jan 24 08:55:36.880: dn_tone_control DN=2 chan 1 tonetype=33:DtInsideDialTone on
off=1 pid=227
Jan 24 08:55:46.880: dn_tone_control DN=2 chan 1 tonetype=0:DtSilence onoff=0 pi
d=227
Jan 24 08:55:46.880: dn_tone_control DN=2 chan 1 tonetype=37:DtReorderTone onoff
=1 pid=227
Jan 24 08:55:46.880: ephone-59[24]:DN 2 disc reason 16 normal state SIEZE
Jan 24 08:55:49.256: ephone-59[24]:ONHOOK (from phone msgID=7)
Jan 24 08:55:49.256: DN 2 chan 1 End Voice_Mode
Jan 24 08:55:49.260: ephone-59[24]:SetCallState line 2 DN 2(-1) chan 1 ref 33801
TsOnHook
Jan 24 08:55:49.260: ephone-59[24]:SpeakerPhoneOnHook
Jan 24 08:55:49.260: ephone-59[24]:---SkinnySyncPhoneDnOverlays is onhook
Jan 24 08:55:49.272: dn_tone_control DN=2 chan 1 tonetype=0:DtSilence onoff=0 pi
d=227
Hall of Fame Super Gold
Re: Resetting efxs ports?
Hi, which exact IOS do you have ?
Issues like that are software bugs and should be corrected in latest images.
Has anyone fixed this issue?  I am having the same issue :
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 08:04 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)XA, RELEASE SOFTWARE (fc1)
System image file is "flash:/uc500-advipservicesk9-mz.151-2.T2"
Last reload type: Normal Reload
Cisco UC560-T1E1-K9 (MPC8378) processor (revision 0x100) with 511180K/13108K bytes of memory.
48 User Licenses
4 Gigabit Ethernet interfaces
24 Serial interfaces
2 terminal lines
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
256K bytes of non-volatile configuration memory.
254464K bytes of ATA CompactFlash (Read/Write)
One channel is active on the DN OCTO-LINE...  then if I want to go offhook on the .2 channel it gives me this error:
120327: Nov  5 04:15:21 CDT: efxs_onhook_offhook: call is already reserved on htsp 50/0/1.2 cdb 0x0EFXS_Glare waits E_HTSP_SETUP_REQ timeout !!
This prohibts call transfer from this DN.  New calls from the PRI come in but can only get put on hold.
Please help.
THanks
Warner
Bronze
Has anyone figured out now to reset the hung efxs port? I put in a work-a-round by removing the number from the ephone-dn and putting it on a new one and using the new ephone-dn on the ephone. I first tried to delete the DN and was going to re-add it, but I can't delete it because it says there is an active call on it.
Mark
There is no published way. Reset ephone, delete and recreate ephone and ephone-dn, are things that can be tried done with variable success. Often, only reload router works.
What should be done in first place, is to update IOS to resolve whatever bug that causes the problem.
Bronze
Paolo,
I scheduled a reboot of the router last night and it was cleared this morning. Your right, an upgrade is the only solution to this issue.
I fixed it with a "Ctrl-alt-del" unfortunately.
Cisco SMB service center didn't have a way.  I did change the config to remove the need for an octo-line. I basically just used multiple ephone-dns sharing the same numbers and then put them in an overlay.
In what version is this issue resolved? Is there a bug id?
Warner
1565
