Restart cucm
hello,
I have to restart my publisher server, I would like to know if there’s any procedure for this and what is the things I have to take in consideration for this task.
Thanks.
Restart it from OS admin or
Restart it from OS admin or CLI
utils system restart
Assuming your system is properly configured for redundancy of call control and services, no, nothing to consider.
java
if this helps, please rate
www.cisco.com/go/pdi
Jaime, Like always you are a
Jaime,
Like always you are a great help, how can i check about the redundancy configuration?
Thanks!
CUCM groups, MRGLs, for
CUCM groups, MRGLs, for services it depends, you might have DNS or SLB, etc.
java
VIP Purple
Also, check the status of
Also, check the status of Database replication prior to restart of Pub.
u can run the command utils dbreplication runtimestate.Should show status as 2 .
regds,
aman
hiRedundancy can be "CUCM if
hi
Redundancy can be "CUCM if you publisher and subscibers " , redundancy for TFTP , redundancy between route groups for outgoing calls , and redundancy for media resources ,etc.. .
1-Redundancy for CUCM servers
1.A- For redundancy you can find under your CUCM group , your CUCMs "publisher and subscriber" . You can go to CUCM system - Cisco CUCM group configuration -find . After this check the result you have to see your CUCM group "the IPs or hostname of your existing CUCM".
2-If you configured TFTP on your CUCM " you can configure redundancy ".
3-Redundancy if you have MGCP configuration , you can check your Voice gateway that can reach your CUCMs.On the output you will see "one is registered and other is backup".
router#sh ccm-manager.
if you have h323 , you can see under configuration redundancy dial-peers which will hit your CUCMs cluster.
dial-peer voice 130 voip                     /this dial-peer will hit my CUCM 1/
 description CALL MANAGER PEER
 destination-pattern 3...
 session target ipv4:10.10.30.2
 incoming called-number .
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 no vad
dial-peer voice 131 voip                     /this dial-peer will hit my CUCM 2 if CUCM 1 unavailable/
 preference 1
 session target ipv4:10.10.30.1
 voice-class codec 1
 voice-class h323 1
 no vad
4-On CUCM if you have more than voice gateway , you can check the redundancy for outgoing calls. For examply " you have E1 and FXO . CUCM  call routing -route/hunt-route list "you can see under configured route list your existing route groups.
Kindly also take a look for the below link
cyruslab.net/2012/10/04/cucm-redundancy-call-processing-failover/
please rate all useful information
75
