Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Restarting the TFTP Service
Hello All,
CallManager: Version 8.0.3...x
I was just wondering if it is safe to restart the TFTP Service on the CallManager without causing any problems during normal business hours.
And hopefully I'm referring to the correct "Service" to restart:
Cisco Unified Serviceability  >  Tools  > Control Center - Feature Services  >  Select Publicher IP Address  > Cisco Tftp (*restart this one?)
If restarting this could mess with anything at all (i.e. calls being dropped, etc...) then I will wait to after hours, but if definitly NOT then I would like to restart it.
Any thoughts would be great!
Thanks in Advance,
Matt
1 ACCEPTED SOLUTION
I have only had 1 issue when restarting the TFTP service during business hours.  If your phones do not currently have the latest firmware loaded onto them, restarting the TFTP service will trigger an update to the phones that have not been upgraded.  The upgrade will obviously take the phones down during that process and cause an outage.  But if all of your phones are currently running the latest firmware on your CUCM then you shouldn't have any issues.
Hey grundle1322, thanks for your quick reply...
Ok that makes sense. I'm not absolutly positive that any phones don't have the latest firmware. But I guess it's better to be safe then sorry!
Thanks for you help.
Thanks Again,
Matt
8023
