Restore CM 4.1(2) to 4.1(3)
I need to rebuild and then restore a backup of CM 4.1.2 but I cannot find the disks. Is there any way I can use 4.1(3) disks and restore into that.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Restore CM 4.1(2) to 4.1(3)
Hi Michael,
Sorry to say, this is not a supported method :( Here is a clip from the CCM 4.1(2) Backup and Restore documentation;
Do a system restore on the same Cisco CallManager version. Changes from release to release cause problems if you try to restore from a different version.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a00802e0e9d.html
Hope this helps!
Rob
1 REPLY
Hi Michael,
Hope this helps!
Rob
89
