Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Restore Database CAR
Hi Guys,
My Customer had a problem with CCM version 4.2.1 related Attendant Console. Cisco suggest change the version to 4.2.3. We need change the machine and the new already is with version 4.2.3. My question is: It's possible restore database CAR of machine with version 4.2.1 to machine version 4.2.3?
Thank You,
Wilson Santana
1 REPLY
Re: Restore Database CAR
restores can only be done on EXACT SAME VERSION FROM WHICH IT WAS TAKEN, exact meaning if you had SR2, restore on SR2, ES45, restore on ES45
java
if this helps, please rate
java
www.cisco.com/go/pdi
106
