12-29-2009 03:55 AM - edited 03-15-2019 08:55 PM
Dear Experts,
Can I use the backup I got from the CUCM 6.1 (via Disaster Recovey System page) and resore it to te CUCM 5.1 directly?
12-29-2009 04:07 AM
Absolutely not, you need to restore on the EXACT SAME VERSION from which you took the backup.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-30-2010 08:26 AM
Hi Java,
But what if you have a brand new load of CUCM 7.1(5b) and your backup is from 6.1(3) and you need to pull the configuration data? How are you supposed to go about restoring that data?
James
12-30-2010 08:30 AM
You upgrade to the exact same version you have your fresh install, take a backup and then restore.
There is no way to restore backups if they're not in the EXACT same version from which they were taken from, that includes any ES or SRs that you might have installed.
Other than that, it means you need to use BAT to manually export and import data.
java
