Restoring a CUCM backup to a spare server
I’m migrating CUCM version 6.1.2(1119-1) to a UCS vmware platform CUCM 8.6. I want to do a backup of the current call manager version 6.1.2(1119-1) and then do a restore on another MCS box running 6.1.2(1112-2) and then upgrade that to CUCM 8.6. My question is that I cannot find the Engineering special 6.1.2(1119-1). If I want to restore the database on the spare Call Manager does the version have to be exactly the same as the original call manager, that is, does the engineering special have to be the exact same?
Thanks in advance,
Marc
  • IP Telephony
Re: Restoring a CUCM backup to a spare server
Hi Marc,
In order to Restore the backup file the versions \ SR \ ES has to be exactly the same as backed up box version. Otherwise Restore will definitely fail.
Caution
Before  you restore Cisco Unified Communications Manager, ensure that the Cisco  Unified Communications Manager version that is installed on the server  matches the version of the backup file that you want to restore.
Reference:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/drs/6_0_1/drs/drsag601.html
Hope it helps.
Anand
Pls rate helpful posts by clicking on the stars below the right answers !!
Hi Anand
Do you think Cisco TAC can send me the correct ES? Because that version is not on their Cisco download page.
Marc
Hi Marc,
Yes, you can try that option.TAC will contcat BU incase if its needed.
And also wait for someone who might help you here in the netpro , in case if they have it.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
Fellow Netpro people, has anyone got the Engineering Special CUCM 6.1(2.1119-1) I can download please.
Thanks in advance,
Marc
279
