Restoring files of 6.1.1 to 6.1.2
Hi all
Is it possible to built a server with 6.1.2 or 6.1.3 and restore the backup file from 6.1.1 ? Will all the configurations be loaded into the 6.1.2 as it was in 6.1.1 with none of the bugs ?
  • IP Telephony
Re: Restoring files of 6.1.1 to 6.1.2
It is only possible to restore a 6.1.1 config file to a 6.1.1 server. You will have to build a 6.1.1 server, then restor the 6.1.1 config and then upgrade to a leter version.
backups are meant to be restored ONLY on the EXACT SAME VERSION from which they were taken.
make sure you install the EXACT SAME 6.1(1) version on the new server to restore
java
if this helps, please rate
java
www.cisco.com/go/pdi
106
