restrict calls out to two extensions?
I need to setup a 7911 IP Phone by our front door so when the reception is out and the front door is locked visitors can pick up the phone and dial one of two extensions to reach somebody to let them in. Is this possible? I am using Call Manager 6.0.1.3
Re: restrict calls out to two extensions?
Yes, configure a CSS that can only reach those 2 phones.
You can configure a translation pattern to act as a middle man and have users dial the TP DN
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Affraid that went flying over my head can you tell me where I would configure both
of those. I should have prefaced my first post with "I have very little to no experience co
nfiguring Cisco 'anything'"
OK, if you're going to deal with CUCM i strongly recommend you to read at least this:
Building Classes of Service for Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html#wp1060032
Partitions and CSS are basic building blocks in CUCM.
I'll assume those 2 phones are already in 1 partition and CSS/partitions are already in place. I'll say they're 1000 and 1001 for the example.
Create a new partition -> css_middle_man
The TP pattern will be something else: let's say 200[01] (that's a regex so it will match 2000 and 2001)
CSS -> i'll assume you already have one that allows to reach internal phones (1000 and 1001), let's say CSS_internal
-> 1XXX (this changes the 1st digit for 1 and leaves the rest as is)
For the phone that you want to reach only those 2 phones create a new CSS that only contains css_middle_man.
The other method is to put the 2 phones you want on that new partitions and modify all the necessary CSSs you have so they can reach the phones. The phone you want to only reach those 2 phones should have a CSS with just that new partitions
EDIT: actually you should start reading this one:
Calling Privileges in Unified CM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.html#wp1044276
java
java
How about just restricting calling out on the phone and only allowing inside calls to extensions? That sounds like it would be easier than trying to do what I originally planned.
Hall of Fame Super Red
Hey ken,
Just to add another option to the great ideas from Java (+5 Java!)
I like your new idea, it's always a good practice to have an "Internal Only"
CSS-Calling Search Space setup on CUCM. You'd be surprised how often
this CSS is used, especially for CFWDALL restrictions. One other thought
here is that if the two phones that you want the "door phone" to access have
spare a Line Button available you could use a "Hotdial' config. Setup a new Shared
Line on the spare buttons (let's say DN 4444) and have the Door Phone dial 4444
as soon as the handset is picked up. No dialing required
The step by step directions in this guide are very good
Hotdial on IP Phones with CallManager Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
This may be further down the rabbit hole than you want to go, but there are solutions designed for door phone usage that allow the internal phone to use the dial-pad to trigger the door to open/unlock, allowing remote access.  We have set up this solution with PLAR (the Hotdial option described above).
229
