Restrict CFA on CME
does someone know if it´s possible to restrict the Call-Forward-All (CFA) function on a single phone
in a Call Manager Express (version 10) environment?
The customer wants to have a password/code to be entered before someone can use CFA function.
Is that possible?
Many thanks
Heinz
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Restrict CFA on CME
Ephone-template
softkey
Often not configured in non-professional installations.
Restrict CFA on CME
You can lock and login to the phone using extension mobility.
Usename/password just for the CFA, is not possible.
Restrict CFA on CME
Thanks.
Is that working in a way that you are able to initiate and pick up calls without logging in before,
and only if you want to change something, i.e. forwarding your phone, you must login?
Re: Restrict CFA on CME
It works with an an unlogged profile for which you can set various properties. However many customer ask first and then do not use it because "too complicated", so it has to be removed. Full details in documentation.
Restrict CFA on CME
Ok, thanks - i will have a look on this.
Would it be possible beside from that, to just completely remove the the CFA feature from a phone?
Restrict CFA on CME
Just remove the softkey.
Please remember to rate useful posts clicking on the star below.
Could you give me a hint of how to remove the softkey? I always used the standard ephone configuration.
Restrict CFA on CME
Ephone-template
softkey
Thanks!
Restrict CFA on CME
Thank you for the nice rating and good luck!
176
