Community Member
restrict external lines
My client has CCME4 set up for 2 departments. they want all outgoing calls from department B use certain PSTN lines, like FXO 1/0/0, 1/0/1. instead of automatic selection. how to set this up?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: restrict external lines
You need to configure an outgoing translation-profile on all the phones that need to use certain pstn lines, to replace the digit used for external calls. For example, if zero is normally used, this example will replace with 9 for Dept B. Then, the correct line is selected with the useful trunk group feature.
voice-port 0/0/0
trunk-group dept-A
voice-port 0/0/1
trunk-group dept-A
voice-port 1/0/0
trunk-group dept-B
voice-port 1/0/1
trunk-group dept-B
dial-peer voice 100 pots
destination-pattern 0T
trunkgroup dept-A
dial-peer voice 200 pots
destination-pattern 9T
trunkgroup dept-B
voice translation-profile 9to0
translate called 20
voice translation-rule 20
rule 1 /^0/ /9/
ephone-dn 20 <--- This DN in dept B
number 201
translation-profile outgoing 0to9
Let us know if it works, please rate if useful post!
voice-port 0/0/0
trunk-group dept-A
voice-port 0/0/1
trunk-group dept-A
voice-port 1/0/0
trunk-group dept-B
voice-port 1/0/1
trunk-group dept-B
trunkgroup dept-A
trunkgroup dept-B
translate called 20
rule 1 /^0/ /9/
number 201
Community Member
Hi, paolo,
Thanks for your reply. I haven't tested it, however, it should work as I analyze. Appreciate your help!
103
