Community Member
Restrict internal calls between phones.
Is it possible to restrict internal calls between 2 phones? Basically, I want the lobby phone of Building A to be able to call 911 and all the phones from Building A, but I don't want it to be able to call other DN from other buildings.
I'm using CCM 4.2
Re: Restrict internal calls between phones.
All this can be achieved with Calling Search Spaces and partitions.
a partition is a logical grouping of DNs
a CSS is a group of partitions that certain DN can reach.
let's say you have 2 partitions
ptA
ptB
and 2 DNs
1000 in ptA
1001 in ptB
now 2 CSS
CSSa = ptA, ptB
CSSb = ptB
DN 1000 has CSSa
DN 1001 has CSSb
1000 can call 1001 since it has ptA & ptB in it's CSS
1001 CANNOT CALL 1000 since ptA is not in the CSS it has assigned
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
I'd actually like to know how to do this as well. I have a phone that I only want to be able to call 4 or 5 internal extensions and 911...can anyone help? I'm using CCM 4.1
follow the exact same principle from my other post.
it's the same thing
Read this and then try:
Calling Privileges in Cisco Unified CallManager
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/4x/42dialpl_ps556_TSD_Products_Implementation_Design_Guide_Chapter.html#wp1043737
java
java
Community Member
Hi java,
Thanks for the reply. Your link leads to a "Forbidden File or Application".
I understand about the relationship between CSS and Partitions but I'm a little unsure how to assign DNs to Partitions. From within CCM, I go to Route Plan > Class of Control > Partition...I can create a partition but only assign it a name and a description...how do I associate DNs with the new partition?
Thanks in advance for your help.
Kurt
Hall of Fame Super Red
Hi Kurt,
Just to fill in for Java for a moment (rather large shoes!)
The DN's will reference the Partitions in this example via the CSS that they are assigned;
Here is the good link;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42dialpl_ps556_TSD_Products_Implementation_Design_Guide_Chapter.html#wp1043737
When you get a link with the forbidden access just remove "partner" from the url :) These don't work for regular users like us.
Hope this helps!
Rob
131
