Restrict PSTN Call Duration
I would like to know that, is it possible we can restrict call duraton of the PSTN Calls for a particular number of users. Like If user making a call from His Phone to the PSTN Cloud, after particular periode of time the call have to get discunnected automatically.
Sunish
1 REPLY
Re: Restrict PSTN Call Duration
You don't mention what you have so I'll assume it's CUCM.
No, we do not provide a method for this.
I'd recommend you to reach Paolo (Look at leaderboard) for this since he has a TCL script for this, you'll need H323 GWs.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
146
