Restricted Access for Cisco Phones - CUCM
Hi All,
I was just wondering if there were a way to allow a partial restriction for user access to the phones.
We are looking to deploy restricted access for security reasons, but would like to be able to see the telephone loads and the network information.
Can this be done on restricted access anywhere?
thanks in advance for any help.
Note You can control whether a phone has access to the Settings menu or to options on this menu by using the Settings Access field in the Cisco Unified Communications Manager Administration Phone Configuration window. The Settings Access field accepts these values:
Enabled—Allows access to the Settings menu.
Disabled—Prevents access to the Settings menu.
Restricted—Allows access to the User Preferences menu and allows volume changes to be saved. Prevents access to other options on the Settings menu.
If you cannot access an option on the Settings menu, check the Settings Access field.
Hall of Fame Super Silver
What you posted is what you
What you posted is what you get, no way to further customize.
Chris
Those things are visible on
Those things are visible on the phone's webpage if you don't mind using that interface to look up those details.
175
