restricted CSS and PRT
Hye guys i have some quries please update me if anyone knows about it
There is my scenario.
In my CCM 5.1 i have around 10 to 15 Partitions and CSS and Route Pattern accordingly. I have around 2 PRIs for calling.
I just want to know how we restrict channels accordingly to CSS and PRT in other words I want to know how we configure
restricted PRT and CSS. Like I want at a time one partition use only 10 channels not more than 10 calls and if someone
try to dial 11th calls and all 10 channels are utilizing they should get busy tone or any message.
And I also have one little question. If I add one phone with SIP protocol and I want to forward that phone calls on any URL how can I do it.
I hope you guys give me a solution soon. I am really thankful to you.
I really appreciate your quick reply.
  • IP Telephony
Re: restricted CSS and PRT
unfortunately just using a T1 PRI and partitions/CSS it's not possible to do what you're looking for
the only possible way i could think of, would be locations between the phones and the GW to limit the available BW. you would need to try this
java
if this helps, please rate
www.cisco.com/go/pdi
thank u soo much i define the bandwidh in location according to requirment and now its working fine thank u so much
131
