Restricted/Unrestricted warning on IP phone firmware upgrade
Hello all -
I'm new to CUCM and I am installing my first phone firmware pack since we had our CUCM install done. Following instructions at http://www.cisco.com/web/software/282074288/113778/cmterm-7821_7841_7861-sip.10-1-1SR2-readme.html. When I try to initiate the install, I get the attached message warning me about upgrading from a "Restricted" version to an "Unrestricted" version. Should I be getting this on a phone firmware file? Should this be ignored or did I do something wrong?
Thank you all for your help.
Adam
1 ACCEPTED SOLUTION
I tried uploading this file
I tried uploading this file on my lab 9.1.1 and 10.0 clusters and did not receive any such warnings. I would suggest opening a TAC case to troubleshoot it further.
Manish
This warning primarily
This warning primarily indicates that once you install an unrestricted version of cucm software it will not allow you to go back to the restricted ( normal ) version. So, you need to choose the appropriate version ( restricted or unrestricted ) while upgrading.
Manish
Manish - Are there restricted
Manish -
Are there restricted/unrestricted versions of phone firmware. Is this just a generic warning that always comes up regardless of what is being installed?
Adam
Hi AdamThis is not an
Hi Adam
This is not an expected behavior or generic warning. This kind of warning only appears when you are upgrading your CUCM/CUC software from restricted to unrestricted or vice versa, but not when you are doing the installation of software cop file for a device.
Can you please paste the following :
1. From the CLI of CUCM (ssh)
show version active
2. From the GUI
Screenshots of steps you are doing before you get to this warning.
Aditya
admin:show version
admin:show version active
Active Master Version: 9.1.2.11900-12
Active Version Installed Software Options:
cmterm-devicepack9.1.2.12033-1.cop
Screenshots are attached. After hitting "next" on the third screen, I get the popup from the previous message.
All Looks good. Just to rule
All Looks good.
Just to rule out the possibility of any  file corruption, would it be possible for you to download the cop file from cisco.com again. Try to install the new file and check if you are getting the same error.
Aditya
I tried a re-download, no
I tried a re-download, no luck. I did a reboot and also tried a different cop file and had the same error. Any ideas?
Manish
I have absolutely no idea
I have absolutely no idea what changed over the weekend, but I just tried again (one more time) before opening a TAC case and it went through without that warning message. Were the planets just misaligned for me last week? I am thoroughly confused.
Thanks everyone for the responses anyways. I guess I can move on to other issues now.
Adam
Thanks for updating the forum
Thanks for updating the forum.
Manish
Hall of Fame Super Red
Hi Adam,This seems unusual
Hi Adam,
This seems unusual for a firmware upgrade. What version of CUCM are you running and are you trying to load the cop.sgn version of the firmware files?
Cheers!
Rob
Running 9.1.2, trying to load
Running 9.1.2, trying to load up cmterm-78xx.10-1-1SR2-1.cop.sgn.
Adam
176
