02-04-2012 08:26 PM - edited 03-16-2019 09:24 AM
Hi All.
One of our all clients is asking for a documentation regarding the differences and comparsion between the Restricted and Unrestricted Versions of the Cisco Unified Call Manager Versions .
I for one know that it is something to do with the regions they are delivered ( North Korea and some other specifications and some encryption and other stuff for US army and all that info regarding the ISO ) , but would really appreciate , where i can get a consolidated cisco doc for the difference between the two types of call manager versions .
Abhishek Singh
02-04-2012 08:45 PM
There isn't one, search CCO for unrestricted + communications manager and you'll pretty much get only RNs/data sheets where this is explained.
The only difference is that one has encryption enabled and the other one does not.
U.S. Export Restrictions on Cisco Unified Communications Manager
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
02-04-2012 09:45 PM
Thanks J ,
For the elaborate explaination.
Abhishek Singh
