02-06-2012 07:32 AM - edited 03-16-2019 09:25 AM
My company is trying to set up an alert system where a mass voicemail can be sent out to select groups in the event of an emergency. The process is pretty straight forward. I was going to allocate a DID extension that routes to Unity and allow the user to leave a message for a group list. The access to this group list needs security. I need to only allow certain phone numbers (on net and off net) to access the emergency extension. Normally, I would do this using partitions and CSS, resticting access to those who's number have the proper CSS. How can I restrict access to all but a select number(s) when a caller is off net? Should this be done through the CO?
I am currently running CUCM 7.1 and Unity 7.0 with a couple of Cisco 2800 series routers (MGCP). We are upgrading to CUCM and Unity 8.5.
We have two trunked PRIs with caller ID.
02-06-2012 08:53 AM
Not sure if CO would oblige with the restriction to all but select number to any DID, you might want to check out. But if they dont, you can call one of those On-net DNs who are given access to Unity Pilot. Apart from the Special user DN, you can create some DNs always forwarded to VM, which can be used for offnet users to call.
Just a thought, you might want to test in your lab. Lemme know how it goes.
GP
Pls rate helpful posts !!
02-17-2015 10:41 AM
Hi Karl - I am trying to do the same thing you are mentioning above.
Did you ever figure out a solution?
Jaime
02-17-2015 10:46 AM
Hi Jamie,
We outsourced that function so the answer became irrelevant. As I understand it, CER (Cisco Emergency Responder) will do this at version 9 and above.
02-17-2015 10:48 AM
Karl - thanks for the info. I'll look into it.
Jaime
