Restricting access to directory on 7921
Is there a way to disable access to the directory (missed, placed & received calls)? I searched the forum but had no luck.
Thanks!
Re: Restricting access to directory on 7921
CUCM version?????
always provide it as things change between versions
java
java
if this helps, please rate
www.cisco.com/go/pdi
Sorry!
System version: 6.1.3.1000-16
unfortunately there is no way to do that on any model on 6.x
java
java
129
