Community Member
Restricting calls on gateways with the caller ID
Can I restrict using the dial-peers with the calling party caller ID ? I mean if the user 111 doesnt have privileges to make a call, how can we block the call on the gateway ?
1 REPLY
Re: Restricting calls on gateways with the caller ID
You always need to specify what you use (CUCM/CME in this case). Either way, it's all CSS/partitions in CUCM or COR in CME.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
137
