Restricting calls to different dial-peers
By setting up sip, it seems that it lets anything that connects to it (registered or not, valid
user or not) make calls to any dial-peer. How do I go about making it so the sip endpoint
can only make a call is if it that sip endpoint registered with cucme? I'm running 4.1.
VIP Super Bronze
Your best bet is to upgrade your IOS to 15.1 (2)T and then implement toll fraud prevention with ip address trust list.
Details here..
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
This seems decent, but what if I have sip endpoints coming from different networks with dynamic ip addresses?
VIP Super Bronze
The whole idea of Toll prevention is that you identify the devices that will be making calls of your infrastructure. If your deployment is such that you are unable to identify them, then I cant see any way you can enforce this. Even if you have devices with dynamic IPs, those ips must belong to a certain subnet/vlan etc. It is assumed that these devices are in your control hence you should be able to define a set of network addresses that are authorised to use your infrastructure.
So just configure all the subnet within your infrastructure and you should be good, I dont see any issue with that at all
Let's say I have 5 endpoints. They're coming in through 5 different locations. Those ips change say, once every 24 hours, same subnet. Do I add those 5 different whole subnets, allowing anyone who happens to be using that same isp to make free phone calls through me if they happen to find my install?
I'm coming over from asterisk. In this setup, you had to be authenticated with the SIP proxy to be able to make outbound calls through this. Testing the security on my setup, I was able to load up X-Lite, put in a random extension number (doesn't exist in voice register dn), the CUCME ip and make a call with no effort.
For authenticated devices, I know how to use cor. For unauthenticated devices, I want a way to keep the call from going through. Perhaps there's a tcl script that could handle this? Something that would maintain an ACL/ip list of registered SIP endpoints.
VIP Super Bronze
If a phone registers to your CCME without them been configured, that suggests you have auto registration enabled. Why dont you disable auto-registration. Thats a good start, this way only devices that are manually configured will register. If an endpoint in not registered on your CCME, they cant make calls through it.
I'm talking SIP here not SCCP. auto-registration only applies to SCCP phones afaik. It's also already turned off.
Like I said, I load up X-Lite, put in the CUCME ip, random extension number, turn off register, no password. Dial a number, it goes through. If I want to be able to allow SIP endpoints to connect remotely, without the need for VPN, I need to open up the SIP port to the WAN. If someone runs across my ip while looking for open SIP servers, they'll get free phone calls.
What I want is to allow the legitimate (authorised) people in, whilse keeping everyone else out.
VIP Super Bronze
Re: Restricting calls to different dial-peers
With SIP endpoints you can configure then to authenticate with authenticate register command e.g.
voice register global
mode cme
source-address x.x.x.x port 5060
authneticate realm all
You will then need to configure each phone with a username and password as follows:
voice register pool 1
id mac x.x.x.x..xx.x..x
type 9951
number 1 dn 1
username cisco password cisco
! --- configure username and password for SIP registration
That's already been set... here is an excert of my config:
! Last configuration change at 11:19:37 PDT Thu Jul 5 2012
! NVRAM config last updated at 11:19:38 PDT Thu Jul 5 2012
version 12.4
service timestamps log datetime msec localtime
service password-encryption
boot-start-marker
boot system flash:c2600-adventerprisek9-mz.124-15.T14.bin
boot-end-marker
enable secret 5 #
enable password 7 #
aaa new-model
aaa authentication login default line
aaa session-id common
clock timezone PST -8
clock summer-time PDT recurring
clock save interval 8
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip name-server 10.0.0.10
voice service voip
allow-connections sip to sip
no supplementary-service sip refer
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 300 min 60
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
video codec h264
mode cme
source-address 10.0.0.5 port 5060
max-dn 10
max-pool 10
authenticate realm yourmom
date-format D/M/Y
mwi stutter
voicemail 1571
tftp-path flash:
create profile sync 002218297029116A
network-locale GB
ntp-server 10.0.0.10 mode directedbroadcast
voice register dn  1
number 2008
call-forward b2bua busy 1572
call-forward b2bua mailbox 2006
call-forward b2bua noan 1571 timeout 20
call-forward b2bua unreachable 1573
no-reg
mwi
id mac 0000.0000.0000
number 1 dn 1
emergency response location 1
presence call-list
dtmf-relay rtp-nte
username 2008 password #
codec g711alaw
no vad
voice emergency response location 1
elin 1 2096224625
call-history-mib retain-timer 500
call-history-mib max-size 500
dial-control-mib retain-timer 35791
dial-control-mib max-size 1200
archive
log config
  hidekeys
gw-accounting syslog
ip address 10.0.0.5 255.255.255.0
no ip route-cache cef
no ip route-cache
duplex auto
speed 100
ip default-gateway 10.0.0.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip http server
no ip http secure-server
ip http path flash:
logging 10.0.0.10
control-plane
dial-peer voice 101 voip
description Voicemail
preference 7
destination-pattern 157[1-4]
session protocol sipv2
session target ipv4:10.0.0.10
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 102 voip
description UK Directory Enquiries
translation-profile outgoing 1
destination-pattern 118...
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 201 voip
description Outbound Calls to Short UK Numbers
destination-pattern 0[1-9]........T
translate-outgoing calling 1
session target sip-server
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 202 voip
description Outbound Calls to the UK
destination-pattern 0[1-9].........
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 301 voip
description Outbound Calls to the US
translation-profile outgoing 10
destination-pattern 001..........
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 401 voip
destination-pattern [2-9].........
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 403 voip
description Calls to the US with 1 infront
destination-pattern 1[2-9].........
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 903 voip
description Emergency Services
emergency response callback
emergency response zone
destination-pattern 911
codec g711alaw
dial-peer terminator A
sip-ua
credentials username # password # realm #
authentication username # password 7 #
no remote-party-id
retry invite 2
mwi-server ipv4:10.0.0.10 expires 3600 port 5060 transport udp unsolicited
registrar dns:.net:5060 expires 300
sip-server dns:.net
connection-reuse
permit hostname dns:voiptalk.org
permit hostname dns:.net
telephony-service
video
no auto-reg-ephone
load 7960-7940 P00308000500
load 7920 cmterm_7920.4.0-03-02
max-ephones 10
max-dn 20
ip source-address 10.0.0.5 port 2000 strict-match
timeouts interdigit 2
url services http://10.0.0.10/cisco/services/
network-locale GB
time-zone 5
time-format 24
date-format dd-mm-yy
voicemail 1571
mwi relay
max-conferences 4 gain -6
moh flash:moh.au
web admin system name # password #
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 001.........
transfer-pattern T
create cnf-files version-stamp 7960 Jul 05 2012 07:05:17
ephone-dn  1
ring internal primary
number 2001 no-reg primary
label 2001
name Holbrook Bunting
preference 1
call-forward busy 1572
call-forward noan 1571 timeout 18
mwi-type both
hold-alert 60 idle
line con 0
password 7 #
line aux 0
password 7 #
line vty 0 4
password 7 #
ntp clock-period 17180381
ntp server 10.0.0.10
end
VIP Super Bronze
Whats the mac address of the x-lite?
Can you do a debug tftp events and a debug ccsip messages. Pls put the output in a text file and attach  here.
I'm not authenticating against mac. Not doing anything with tftp. I put in the user: 100, password: random,
there is no voice register pool for '100'. This is me, using x-lite as 100 to call voicemail at 1571 in ccsip debug:
Also, X-Lite is set to not try to authenticate to the server, it is only sending an invite as shown below.
Received:
INVITE sip:1571@10.0.0.5 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.112:29378;branch=z9hG4bK-d8754z-66a0eb138318a27e-1---d8754z-;rport
Max-Forwards: 70
Contact: <100>
To: <1571>
Call-ID: MzgxMzg5MDIzN2Y3ZWYyNTBkYTQ4NDVkZTk3NzQ0NDA.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Content-Type: application/sdp
Supported: replaces
User-Agent: X-Lite 4 release 4.1 stamp 63215
Content-Length: 368
v=0
o=- 1341514242917947 1 IN IP4 10.0.0.112
s=CounterPath X-Lite 4.1
c=IN IP4 10.0.0.112
t=0 0
a=ice-ufrag:764d30
a=ice-pwd:86a38c0354a795fdbd44d2ba728664e3
m=audio 54432 RTP/AVP 0 8 101
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=candidate:1 1 UDP 659136 10.0.0.112 54432 typ host
a=candidate:1 2 UDP 659134 10.0.0.112 54433 typ host
Jul  5 18:50:42.977: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <1571>
Date: Thu, 05 Jul 2012 18:50:42 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Jul  5 18:50:43.009: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1571@10.0.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.5:5060;branch=z9hG4bK15B1EC5
From: "Holbrook Bunting" <>100@sip.didlogic.net>;tag=3AFEE2C-808
To: <1571>
Date: Thu, 05 Jul 2012 18:50:43 GMT
Call-ID: 283DCE72-C60911E1-82A698E5-1454431A@10.0.0.5
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 674579218-3322483169-2191628517-341066522
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1341514243
Contact: <100>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 259
v=0
o=CiscoSystemsSIP-GW-UserAgent 5217 9966 IN IP4 10.0.0.5
s=SIP Call
c=IN IP4 10.0.0.5
t=0 0
m=audio 19542 RTP/AVP 8 101 19
c=IN IP4 10.0.0.5
a=rtpmap:8 PCMA/8000
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
Jul  5 18:50:43.029: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.0.5:5060;branch=z9hG4bK15B1EC5;received=10.0.0.5;rport=5060
To: <1571>
CSeq: 101 INVITE
Server: Asterisk PBX 1.8.14.0-rc1
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Contact: <1571>
Content-Length: 0
Jul  5 18:50:43.037: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <1571>;tag=as76eb1181
CSeq: 101 INVITE
Contact: <1571>
Content-Length: 260
v=0
o=root 951921662 951921662 IN IP4 10.0.0.10
s=Asterisk PBX 1.8.14.0-rc1
c=IN IP4 10.0.0.10
t=0 0
m=audio 10380 RTP/AVP 8 101
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Jul  5 18:50:43.057: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1571@10.0.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.5:5060;branch=z9hG4bK15C796
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Jul  5 18:50:43.081: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <1571>;tag=3AFEE74-E5D
CSeq: 1 INVITE
Contact: <1571>
Supported: replaces
Content-Length: 262
v=0
o=CiscoSystemsSIP-GW-UserAgent 2921 9932 IN IP4 10.0.0.5
s=SIP Call
c=IN IP4 10.0.0.5
t=0 0
m=audio 18942 RTP/AVP 8 101
c=IN IP4 10.0.0.5
a=fmtp:101 0-16
a=ptime:20
Jul  5 18:50:43.097: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1571@10.0.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.112:29378;branch=z9hG4bK-d8754z-c4d913069f90f573-1---d8754z-;rport
Max-Forwards: 70
Contact: <100>
CSeq: 1 ACK
Content-Length: 0
Jul  5 18:50:44.557: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:1571@10.0.0.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.112:29378;branch=z9hG4bK-d8754z-fbcb1966311d4207-1---d8754z-;rport
Max-Forwards: 70
Contact: <100>
CSeq: 2 BYE
Content-Length: 0
Jul  5 11:50:44.573: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 28354312C60911E182A198E51454431A, SetupTime 11:50:42.963 PDT Thu Jul 5 2012, PeerAddress 100, PeerSubAddress , DisconnectCause 10  , DisconnectText normal call clearing (16), ConnectTime 11:50:43.073 PDT Thu Jul 5 2012, DisconnectTime 11:50:44.573 PDT Thu Jul 5 2012, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 73, TransmitBytes 11680, ReceivePackets 60, ReceiveBytes 9600
Jul  5 11:50:44.577: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:07/05/2012 11:50:42.965,cgn:100,cdn:1571,frs:0,fid:129,fcid:28354312C60911E182A198E51454431A,legID:296,bguid:28354312C60911E182A198E51454431A
Jul  5 18:50:44.585: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Thu, 05 Jul 2012 18:50:44 GMT
CSeq: 2 BYE
Reason: Q.850;cause=16
Content-Length: 0
Jul  5 18:50:44.589: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:1571@10.0.0.10:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.5:5060;branch=z9hG4bK15D301
Max-Forwards: 70
Timestamp: 1341514244
CSeq: 102 BYE
Content-Length: 0
Jul  5 18:50:44.601: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.0.5:5060;branch=z9hG4bK15D301;received=10.0.0.5;rport=5060
CSeq: 102 BYE
Content-Length: 0
VIP Super Bronze
Well, are you saying that this x-lite phone is not registered to your ccme? I only asked for mac because the the authentication credential is defined on the phone and the phone is identified by the mac.  All the while i assume the phome is registered. If the phone is  not registered then afaik the only way to prevent this is to use ip address trust list as I mentioned earlier
the configuration area you should be looking at is called "Class of Restriction" or COR.
The COR implements a lock/key model where phone and dial-peers are given keys/locks definitions (essentially matching outgoing/incoming COR identifier).
I found the most understandable description of this in the (Cisco Press) book: "Cisco Voice Gateways and Gatekeepers" - Chapter 12.
This provides a much clearer description of how COR works that the ios example on Cisco site.... which are very hard to follow.
I am currently trying to solve a simillar problem via COR, so cannot provide definitive answer, but believe this the right place to start digging.
Cheers,
John.
Hi John,
Thanks for the suggestion. I fiddled around a little with COR earlier, only placing one on the voicemail
extension and seeing what happened. From my observation, it looks like COR only works when it is
applied to a phone/dn. When there is no COR on one, it has unlimited access.
This is kind of an irony, that Cisco would develop a system like COR and ip restrictions, but leave such
a big hole. You go to the trouble of placing COR's in place, Employee John can't call India, but alas (as
long as SIP is running and he gets the CUCME ip from his phone), he loads up a SIP soft client onto
his workstation and presto, he can call India (so long as the dial-peer exists matching the dial patterm).
VIP Super Bronze
I have done a few research on this and I also found out that with SIP endpoints, the IP address trust authenticate I mentioned is ignored. So that is not even an option. The only other option is to use ACL.
ip extended access-list PREVENT_TOLL_FRAUD
permit tcp host (trusted_remote_ip/phone subnet) host (my_rtr_loopback_ip/ccme ip) eq 5060
Then apply it to your interface
interface
ip access-group PREVENT_TOLL_FRAUD in
816
