Restricting ccmhelpdesk access
Is it possible to allow a user, by default, access to all DN's except for a select few? I have some DN's that absolutely cannot be changed.
Re: Restricting ccmhelpdesk access
CUCM??? ALWAYS mention what you use
if so not with MLA, MLA grants access to menus and provides a security level of view only, change but is not granular to the level of which DNs you can view an account
java
if this helps, please rate
java
www.cisco.com/go/pdi
Sorry, 6.1
Hi!
Not sure what's the exact CCM version you have. If it's a 4.X version you can use MLA or if it's 5.X or later you can confifure roles and user groups to restrict access to admin users.
Check these links:
** Multilevel Administration Configuration **
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_3/ccmcfg/b07mla.html
*** Cisco Unified Communications Manager System Guide, Release 6.1(1) ***
--> Roles and User Groups
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmsys/a02mla.html
Have a nice day!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
I have checked out that document before, but the roles are on a global scale; all DN's or none. I need helpdesk to have access to create/modify/edit all DN's, but need to have them in a RO mode for a select few DN's.
MLA doesn't go that far, i believe there is a 3rd party solution that could do this. i cannot find it right now but you can try searching NetPro as it has been posted previously
java
java
127
