Restriction list in jabber
I have a scenario for Jabber client for windows & IPhones,End users should able to make a Long distance call from deskphone,when the login to client they should to have a restriction for Long distance calls.,suggest me on how to upload restriction list through xml file.
Any suggestion on this
This is no different from any
This is no different from any other DN, it comes down to your CSS and partition config, that's it.
If this is a shared line, no way to do what you're asking, you would need to set a different DN.
.xml files have absolutely nothing to do with what you're asking.
java
if this helps, please rate
www.cisco.com/go/pdi
Dear Jaime,I understood guys
I understood guys @jaime @minkdennis
What you are trying to do is
What you are trying to do is not possible, assuming you are using the same extension on your Jabber "softphone" as on your deskphone.
Please remember to rate useful posts, by clicking on the stars below.
37
