retain + on phone display for called number on h323 gw
hi,
I just wondering if anyone run into this issue and has any suggestions.
basically its a cucm with h323 gateway. when someone dials a local/long distance, i take that and globalize it to add +1. so it will show up on the phone display as +1 followed by local /long distnace #. (ex.+14162221111)
the problem is that, ,the call manager is doing it correctly however as soon as it reaches the 323 gateway, i have a dialpeer that takes the sent called number with 9 followed by local /long distance # strips the 9 and sends it out of PRI.. as soon as it strips the 9, teh phone display of hte called number changes from +14162221111 to 4162221111.
how do we make sure that called # on the display remains +1 but gateway while gateway strips the 9.
thanks
vijay
It should work if you set the service parameter "Always Display Original Dialed Number" to true
Re: retain + on phone display for called number on h323 gw
nope that will retain the actual dialed number 9 followed by 10 digits
Oh I missed that you were globalizing. I thought that the users were dialing with +1
153
