05-04-2010 01:07 PM - edited 03-15-2019 10:37 PM
Existing 7.1.2 cluster, wishing to add a retired CM4 server, for the purpose of serving as a dedicated tftp server. Is the upgrade path the same as if it were a new cluster? or does it change b/c its joining an existing cluster?
05-04-2010 01:12 PM
You basically need to follow the instructions on how to add a subscriber to the cluster
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/7_1_2/install/cmins712.html#wp485892
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-04-2010 01:14 PM
If by upgrade path you mean ordering an upgrade kit and getting licenses, etc. Then yeah, more or less.
If by upgrade path you mean you would use DMA, then no. You will want to check the hardware (cpu/ram/hdd) to make sure it lines up with (a) supported hardware and (b) your existing cluster capacity/server models. For example, don't stick a mcs 7825 into a cluster of mcs 7845 servers hosting 10,000 users. That is asking for trouble.
All you really need (once you validate the hardware) is a valid node license (the upgrade kit will get you this) and the software install media (upgrade kit or existing is fine). You will then add the server as a new cluster subscriber. Basically it is a new install of server into an existing system, not an upgrade.
HTH.
Bill
