retrieving personal directory
one user moved to a new location, unplugged his phone and plugged it in the new location. then when he went to his personal address book, there was nothing in it. is there a way of retrieving it? we are using call manager 4.1.(3). Not Call Manager Express, the real Call Manager.
Re: retrieving personal directory
same ip subnet?
connectivity?
the data is on CUCM so you should be able to retrieve it.
exactly what happens on the phones? what do you see/get?
java
if this helps, please rate
java
www.cisco.com/go/pdi
you can login to the CCM User page to check if it shows up there. https://x.x.x.x/ccmuser
do you see the IP phone service? Are you able to login?
try removing and re- adding the service to the phone.
In the CCM Admin - is the IP phone service defined using an IP or hostname? If it is hostname, does the dhcp include dns.
:JoeL
130
