Reviewing CSSes
I have to review a lot of CSSes that have a lot of partitions in them to verify that they are configured properly. I don't see any way to export the configuration of the CSSes via the BAT tool. Is there any other way to do this so that I don't have to manually click on each CSS and scroll through the list of Partitions?
THX!
1 ACCEPTED SOLUTION
Re: Reviewing CSSes
Hi Aaron,
In CUCM 6.X or later, there is an option to Import/Export configuration in CSV format.
If you navigate to Bulk Administration->Import/Export->Export you can check which data can be exported (this includes CSS).
Hope this helps.
Best regards,
- Adrián.
Bronze
Re: Reviewing CSSes
This is not supported feature as of now in BAT.
Your probably need to run a SQL query for this
Re: Reviewing CSSes
Hi Aaron,
Hope this helps.
Best regards,
- Adrián.
Re: Reviewing CSSes
Adrian. That did the trick. THX!
135
