Rightfax 9.3 - Configuration Problem (character set...)
I finished installing a Rightfax solution - Cisco Fax Server. Everything is working
except that the characters on the -cover sheet- variable fields appear wrong
Examples:
í -> appear Ý
ã -> appear Ò
And this sort of things. We know that is some issue with character set, but we dont know where
to check more to use our language characters.
Can anybody heeeeelp...or have an hint?
Thank you
Met
1 REPLY
Re: Rightfax 9.3 - Configuration Problem (character set...)
Problem resolved: checked ANSI checkbox on database module.
Met
147
