07-18-2012 03:13 AM - edited 03-16-2019 12:15 PM
Anybody has done the integration mentioned in the subject line. My layer 1 is showing active but layer 2 status is showing TEI_ASSIGNED. Configuration has been attached. Any help would be greatly appreciated.
Solved! Go to Solution.
07-18-2012 03:25 AM
Mohammed,
I doubt very much if the rightfax end of the PRI will be the network end.
Change you config at the router end to be the NETWORK
interface Serial0/0/1:15
shut
description ### E1 PRI connected to RIGHTFAX ###
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
isdn protocol-emulate network
no shut
show isdn status
See how this goes
Alex.
Please rate useful posts.
07-18-2012 03:25 AM
Mohammed,
shut
no ip address
encapsulation hdlc
no cdp enable
no shut
show isdn status
See how this goes
Alex.
07-25-2012 11:46 PM
Layer 2 is mulitframe established after adding the below command, but now the call goes through From VG to Right FAX only once in a while and viceversa also is not working. It keeps giving busy signal. Below is the debug isdn outputs.
debug isdn q931
RIGHTFAX-VG#
*Jul 18 15:37:51.671: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00D6
Cause i = 0x80E6 - Recovery on timer expiry
*Jul 18 15:37:54.387: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x21E2
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18392
Preferred, Channel 18
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '026423000'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '106'
Plan:ISDN, Type:Subscriber(local)
*Jul 18 15:37:54.387: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0xA1E2 callID = 0x0021 switch = primary-net5 interface = User
*Jul 18 15:37:54.387: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num 9026423000
*Jul 18 15:37:54.387: ISDN Se0/0/1:15 Q931: Sending SETUP callref = 0x00D7 callID = 0x8013 switch = primary-net5 interface = Network
*Jul 18 15:37:54.387: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xA1E2
Channel ID i = 0xA98392
Exclusive, Channel 18
*Jul 18 15:37:54.387: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x00D7
Sending Complete
Standard = CCITT
Channel ID i = 0xA98381
Calling Party Number i = 0x2183, '9026423000'
Called Party Number i = 0xC1, '4160106'
*Jul 18 15:37:55.387: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x00D7
Sending Complete
Standard = CCITT
*Jul 18 15:37:56.387: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x00D7
Sending Complete
Standard = CCITT
*Jul 18 15:37:56.771: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x0001
Cause i = 0x8090 - Normal call clearing
*Jul 18 15:37:56.771: ISDN Se0/0/1:15 **ERROR**: L3_BadPeerMsg: event 0x4D cr 0x8001 callid 0x0
*Jul 18 15:37:57.387: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x00D7
Sending Complete
Standard = CCITT
*Jul 18 15:38:00.771: ISDN Se0/0/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x0001
*Jul 18 15:38:00.771: ISDN Se0/0/1:15 **ERROR**: L3_BadPeerMsg: event 0x4D cr 0x8001 callid 0x0
*Jul 18 15:38:00.771: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8001
Cause i = 0x80D1 - Invalid call reference value
*Jul 18 15:38:01.771: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8001
*Jul 18 15:38:02.387: ISDN Se0/0/1:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
*Jul 18 15:38:02.387: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xA1E2
Cause i = 0x8092 - No user responding
*Jul 18 15:38:02.555: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x21E2
*Jul 18 15:38:02.555: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA1E2
*Jul 18 15:38:02.771: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8001
*Jul 18 15:38:02.775: ISDN Se0/0/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00D7
debug isdn q921
*Jul 18 14:22:24.555: ISDN Se0/0/1:15 Q921: Net RX <- RRp sapi=0 tei=0 nr=1
*Jul 18 14:22:24.999: ISDN Se0/0/1:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jul 18 14:22:24.999: ISDN Se0/0/1:15 Q921: Net RX <- UAf sapi=0 tei=0
*Jul 18 14:22:27.999: ISDN Se0/0/1:15 Q921: Net TX -> INFO sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:27.999: ISDN Se0/0/1:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
*Jul 18 14:22:27.999: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=28 nr=19
*Jul 18 14:22:28.023: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=29
*Jul 18 14:22:28.155: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=19 nr=29
*Jul 18 14:22:28.155: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=20
*Jul 18 14:22:28.155: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=29 nr=20
*Jul 18 14:22:28.179: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=30
*Jul 18 14:22:28.999: ISDN Se0/0/1:15 Q921: S7_T200_EXPIRY: VA = 0, VS = 1
*Jul 18 14:22:28.999: ISDN Se0/0/1:15 Q921: Net TX -> INFOp sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:29.999: ISDN Se0/0/1:15 Q921: Net TX -> INFOp sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:30.999: ISDN Se0/0/1:15 Q921: Net TX -> INFOp sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:31.999: ISDN Se0/0/1:15 Q921: L2_EstablishDataLink: sending SABME
*Jul 18 14:22:31.999: ISDN Se0/0/1:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jul 18 14:22:32.999: ISDN Se0/0/1:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jul 18 14:22:32.999: ISDN Se0/0/1:15 Q921: Net RX <- UAf sapi=0 tei=0
*Jul 18 14:22:36.791: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=20 nr=30
*Jul 18 14:22:36.791: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=21
*Jul 18 14:22:36.791: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=30 nr=21
*Jul 18 14:22:36.791: ISDN Se0/0/1:15 Q921: Net TX -> INFO sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:36.815: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=31
*Jul 18 14:22:37.791: ISDN Se0/0/1:15 Q921: S7_T200_EXPIRY: VA = 0, VS = 1
*Jul 18 14:22:37.791: ISDN Se0/0/1:15 Q921: Net TX -> INFOp sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:38.791: ISDN Se0/0/1:15 Q921: Net TX -> INFOp sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:39.791: ISDN Se0/0/1:15 Q921: Net TX -> INFOp sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:40.791: ISDN Se0/0/1:15 Q921: L2_EstablishDataLink: sending SABME
*Jul 18 14:22:40.791: ISDN Se0/0/1:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jul 18 14:22:41.791: ISDN Se0/0/1:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jul 18 14:22:42.791: ISDN Se0/0/1:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jul 18 14:22:42.791: ISDN Se0/0/1:15 Q921: Net RX <- UAf sapi=0 tei=0
*Jul 18 14:22:44.791: ISDN Se0/0/1:15 Q921: Net TX -> INFO sapi=0 tei=0, ns=0 nr=0
*Jul 18 14:22:44.791: ISDN Se0/0/1:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
*Jul 18 14:22:44.791: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=31 nr=21
*Jul 18 14:22:44.815: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=32
*Jul 18 14:22:44.943: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=21 nr=32
*Jul 18 14:22:44.943: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=22
07-26-2012 06:33 AM
This may be due to the wrong ISDN switch type at one of the ends
You are set to use
Are you sure this is what the Right FAX is set to ?
Alex.
