Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
RightFax T38 with stcapp controlled FAX
I have a RightFax connected to a CUCM v6 through a SIP trunk. VGs are configured for T38 with fallback cisco protocol. Some faxes are connected directed on FXS on VG, and controlled by CUCM via STCAPP service protocol.
OK: from RightFax --> Fax Rx/Tx to/from PSTN work OK.
PROBLEM: from RightFax --> Fax Rx/Tx to/from STCAPP fax cannot negotiate T38 (see attached wireshark trace: not acceptable media)
Here is the config:
stcapp register capability 0/3/0 both
stcapp ccm-group 1
stcapp
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice-port 0/3/0
cptone CH
timeouts ringing infinity
caller-id enable
dial-peer voice 415800 pots
service stcapp
port 0/2/0
dial-peer voice 415801 voip
description TEST T38
preference 1
voice-class codec 1
incoming called-number 415800
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
WORKAROUND:
I managed to send fax by forcing the CUCM to reroute to the VG via H323, by inserting a new route pattern (9.415800 predot) and a creating an additional dial-peer on the VG:
dial-peer voice 415802 pots
preference 1
destination-pattern 415800
port 0/2/0
--> SUCCESS !! T38 is negotiated correctly
--> Does anyone having an idea of what can cause this problem ?
--> Does anyone having succeeded in making T38 call to STCAPP controlled fax in a similar set-up ?
1 ACCEPTED SOLUTION
Re: RightFax T38 with stcapp controlled FAX
SCCP does not support protocol based T38. You would need to use SIP/H323/MGCP for this functionality to work.
As well, there are almost no additional features gained by a fax machine for a SCCP controlled port rather than MGCP. Or SIP/H323 if you don't mind configuring things on the gateway.
-nick
-nick
Hi Nick,
thanks for your reply. Now I understand the protocol mismatch error...
For FXS/SCCP on voice gateways, I see following advantages: 1. customer can control line parameter directly from CUCM (like MGCP), and 2. SRST support (not possible with MGCP, right?)
I guess it makes sense to keep SCCP, and had transtation/partition to redirect inbound T38 calls from the rightfax SIP trunk to VGs via H323 (already configured for PSTN).
973
