Community Member
RightFax with CCM Environment
With Rightfax 9.0 with a T.38-Compatible Fax Board, am correct that the only connection from the Fax server will be over ethernet into the Cisco Voice Gateway?
And am I correct that in this setup I can send faxes over IP to branch sites or over the PSTN (to any fax machine in the world)?
Re: RightFax with CCM Environment
You can do this two ways. If you have a T38 compatible board, yes you can setup your voice gateway for t38 as well and then send faxes to other branch sites (enabled with t38 on their gateways as well) or to the pstn.
If you have a brooktrout t1 card on ur right fax server, you can cross connect that to the router and set up that link as a PRI. You can then send it to any fax machine across ur enterprise or to the pstn.
Sankar
pS: please remember to rate posts!
Community Member
Thanks for the detailed response Sankar.
Community Member
Sankar, There is a better solution out there than Rightfax. XMediusFAX from Sagem-Interstar. It does not require any fax boards, is easier to setup and truly leverages the Cisco UCM and gateways infrastructure. It uses H.323, MGCP or SIP and T.38. It's got all the bells & wistles of RF, yet it is a more robust solution.
Community Member
I recommend you contact Sagem-Interstar and look at their XMediusFAX solution. It does not require any fax boards in the fax server and truly leverages your Cisco IP infrastructure through T.38. It supports setup with H.323, MGCP and SIP. Much simpler to work with and a real good product.
187
