RightFax
We have been having issues with T.38 negotiate failing between our CUCM 8.6 and a RightFax server. Anyone have any documentation on the setup for RightFax? Are configuration is PSTN--(SIP)--CUCM--(SIP)--RightFax server.
Tommy
RightFax
Hi Tommy,
you need to add sip trunk or add the rightfax as an H323 gateway on CCM.
you need also to create route pattern using rightfax in the route list.
Anas
please rate all the helpful posts
RightFax
Abu,
Thaks for the reply.
We have the SIP trunk and route pattern configured. If the RightFax server is configured for T.38 the CCM does not responde to the T.38 invite. I am guessing we have something not configured on the SIP trunk or SIP profile, unfortnately I do not have access to the RightFax server and the only documention I have been given is for CCM 7.0 and earlier, was looking for the correct setting for the SIP trunk and SIP profile.
Tommy
Re: RightFax
Tommy,
Have you found the resolution to this?  I am currently experiencing the exact same issue and working with RightFax/OpenText hasn't gotten me anywhere...
UPDATE:  Not sure if your using just a PSTN PRI, but I am attempting to use PSTN SIP, after working some more with the provider I have found that the PSTN Sip circuit does not support T.38, I'll update your thread if I get a work around from OpenText.
RightFax
Hi Tommy,
     Any chance you could get me the CCM detailed traces for a failed call?
Jagpreet
255
