Ring Back Tone issue
Dear all:
I need some light to continue troubleshooting a Ring Back tone issue. The problem is that it is only happening when someone calls to the USA DID number from an USA line. ( I tested from an Argentina trunk and Germany trunk and there is RBT)
I have a CUCME wich is also an H323 gateway.
This is the topology more or less:
[USA DID Provider] ---SIP Trunk---[SBC]---GK/H323----[CME]----IP Phones
This is the config
voice call send-alert
voice rtp send-recv
voice service voip
h323
  ras rrq dynamic prefixes
voice class codec 1
codec preference 1 g729r8 bytes 60
dial-peer voice 1 voip
huntstop
destination-pattern .T
voice-class codec 1
session target ras
dtmf-relay h245-alphanumeric
fax protocol t38 nse ls-redundancy 2 hs-redundancy 2 fallback pass-through g711alaw
dial-peer voice 3 voip
voice-class codec 1
incoming called-number .T
gateway
timer receive-rtp 1200
telephony-service
max-ephones 20
max-dn 144
ip source-address x.x.x.x port 2000
auto assign 1 to 20
service phone pcPort 1
service phone settingsAccess 2
timeouts interdigit 3
  time-zone 25
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
transfer-pattern *
transfer-pattern .T
ephone-dn  1  dual-line
number xxx no-reg primary
ephone-dn  2  dual-line
ephone  1
mac-address x.x.x
type 7941
button  1:2
ephone  2
mac-address x.x.x
type 7942
button  1:1
I tested serveral configurations regarding RBT:
- Remove the global voice call send-alert
- Configured the progress_ind setup enable 3, 1, 0 under dial-peer 1
- Configured the tone ringback alert no PI
- Tested the delay transport address command
Can anyone help me? Which debugs should i run to proper catch this?
Thanks!!
Marcelo
Everyone's tags (3)
One more:
If i assing the USA DID to an extension that is behind an other H323 gateway with FXS cards, I can heard the ring back tone.
Any idea?
Debug cch323 h225  - This is the call to the DID
un 10 22:50:17.535: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPIND_CHOSEN
Jun 10 22:50:17.535: //-1/xxxxxxxxxxxx/H323/setup_ind: Entry
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/setup_ind: callingNumber[3055391450] calledNumber[2362201202]
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/setup_ind: ---- calling IE present
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/setup_ind: ====== PI = 0    ---> This could be the problem?
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/setup_ind: Receive: infoXCap 0
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/setup_ind: Receive: infoXCap ccb 0
setup_ind: is_overlap = 0, info_complete = 0
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/cch323_h225_receiver: SETUPIND_CHOSEN: src address = 172.31.13.253; dest address = 200.12.222.11
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_FS_SETUP_IND while at state H225_IDLE
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/idle_fsSetupInd_hdlr: Setup ccb 0x48EEEAE8
Jun 10 22:50:17.535: //882/67DF242B1C92/H323/act_fastStartSetupInd: full match is found
Jun 10 22:50:17.539: //882/67DF242B1C92/H323/act_fastStartSetupInd: codec match = 1
Jun 10 22:50:17.539: //882/67DF242B1C92/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_WAIT_FOR_ARQ state
Jun 10 22:50:18.131: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_RAS_SUCCESS while at state H225_REQ_FS_WAIT_FOR_ARQ
Jun 10 22:50:18.131: //882/67DF242B1C92/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_WAIT_FOR_ARQ state to H225_REQ_FS_SETUP state
Jun 10 22:50:18.131: //882/67DF242B1C92/H323/cch323_create_incoming_callinfo_block: peer 45580F14, voice_peer_tag 3, ccb: 48EEEAE8
Jun 10 22:50:18.135: //882/67DF242B1C92/H323/cch323_h225_handle_deferred_ind: UnBuffering deferred indications
Jun 10 22:50:18.147: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_CALLPROC while at state H225_REQ_FS_SETUP
Jun 10 22:50:18.147: //882/67DF242B1C92/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_ACC_FS_CALLPROC state
Jun 10 22:50:18.147: //882/67DF242B1C92/H323/generic_send_callproc: ====== PI = 0
Jun 10 22:50:18.147: //882/67DF242B1C92/H323/fastStartIdle: ccb->status_1 = 0x1
Jun 10 22:50:18.155: //-1/xxxxxxxxxxxx/H323/cch323_post_call_service_msg: callID=882, notify data mask=0x00000007
Jun 10 22:50:18.155: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_ALERT while at state H225_ACC_FS_CALLPROC
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/cch323_h225_set_new_state: Changing from H225_ACC_FS_CALLPROC state to H225_ACC_FS_ALERT state
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/generic_send_alert: ====== PI = 0
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/generic_send_alert: get ALERT displayInfo
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_NOTIFY while at state H225_ACC_FS_ALERT
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/send_notify_msg: Notify data found, mask=0x00000007
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/send_notify_msg: Sending NOTIFY Display Info IE =
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/send_notify_msg: Sending NOTIFY Notification Indicator IE = 113
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/send_notify_msg: Sending NOTIFY Connected Number as ASN non-std
Jun 10 22:50:18.159: //882/67DF242B1C92/H323/send_notify_msg: [cnum]/[oct]/[oct3a] = [2362201202]/[0x00]/[0x00]
Jun 10 22:50:18.735: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type FACILIND_CHOSEN
Jun 10 22:50:18.735: //882/67DF242B1C92/H323/cch323_h225_receiver: FACILIND_CHOSEN: src address = 172.31.13.253; dest address = 200.12.222.11
Jun 10 22:50:18.735: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_FACILITY_IND while at state H225_ACC_FS_ALERT
Jun 10 22:50:18.739: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_TRANSMIT_TUNNELING while at state H225_ACC_FS_ALERT
Jun 10 22:50:18.743: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type FACILIND_CHOSEN
Jun 10 22:50:18.743: //882/67DF242B1C92/H323/cch323_h225_receiver: FACILIND_CHOSEN: src address = 172.31.13.253; dest address = 200.12.222.11
Jun 10 22:50:18.743: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_FACILITY_IND while at state H225_ACC_FS_ALERT
Jun 10 22:50:18.743: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_TRANSMIT_TUNNELING while at state H225_ACC_FS_ALERT
Jun 10 22:50:19.299: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type FACILIND_CHOSEN
Jun 10 22:50:19.299: //882/67DF242B1C92/H323/cch323_h225_receiver: FACILIND_CHOSEN: src address = 172.31.13.253; dest address = 200.12.222.11
Jun 10 22:50:19.299: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_FACILITY_IND while at state H225_ACC_FS_ALERT
Jun 10 22:50:20.059: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type FACILIND_CHOSEN
Jun 10 22:50:20.059: //882/67DF242B1C92/H323/cch323_h225_receiver: FACILIND_CHOSEN: src address = 172.31.13.253; dest address = 200.12.222.11
Jun 10 22:50:20.059: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_FACILITY_IND while at state H225_ACC_FS_ALERT
Jun 10 22:50:20.059: //882/67DF242B1C92/H323/run_h225_sm: Received event H225_EV_H245_SUCCESS while at state H225_ACC_FS_ALERT
735
