Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Ring-back Tone
I have this problem, A PBX user places a call to an Cisco IP phone, and does not hear a ringback tone before the call is answered. The cisco call manger is 6.0 version and the H.323 gateway is the 3545 pri gateway. What can I do ?. A Cisco IP phone user place a call to PBX user, and tone ringback is heard.
Re: Ring-back Tone
This could be attributed to the fact that the gateway was unable to determine the progress-indicator in the call setup and consequently could not cut-through the audio befor the call was answered.
You could try a couple of commands on the gateway:-
Initially configure the 'voice call send-alert' in global.
If this does not appear to working the configure the following commands on the incoming call-leg dial-peer. These generally hidden commands.
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
Rgds
Allan.
Re: Ring-back Tone
thanks allan.thomas, but this commands are avalaible in the Cisco 3545 PRI Gateway ?
Re: Ring-back Tone
Apologies for the delay, the information that I have provided in most cases will resolve ringback issues on call-legs between IOS gateways and PBX.
When you mentioned that you had ringback issue, I overlooked the fact that it was not in relation to IOS gateway.
Sorry.
Re: Ring-back Tone
HI ricardo, have you solve this issue? couse i have the same?, there´s one difference, i have a gateway 2600 series. Could you help me please?
Silver
Re: Ring-back Tone
Have you engaged the MTP in the CUCM by checking the checkbox in the gateway configuration page?
MK
Re: Ring-back Tone
hi MK
i already did, but don´t work jet. any idea?
thanks for yor help.
Silver
Re: Ring-back Tone
What kind of PBX do you have? Is it connected to a Cisco router? If so, make sure you have the "progress ind setup 3" command under the dial-peer in the router connected to the PBX.
MK
Re: Ring-back Tone
Hi MK thanks for your help.
i have this scenario:
a PBX Alcatel with a link  E1 QSIG to Cico Router  2620, and the Gateway is registered as H323 gateway at CCM 6. And i already configured "progress ind setup 3" under dial-peer voip. So is there a parameter tha i must to change at the CCM?.
best regards
570
