Ring Duration
Phone keeps ringing irrespective of the No answer ring duration set under line settings. Any info appreciated.
Thanks.
Hall of Fame Super Red
Re: Ring Duration
Hi Gary,
The "No answer ring duration" only comes into play in conjunction with a "Forward No Answer" setting under the DN config. If there is no "Forward No Answer" setup the phone will ring forever until the far-end hangs up :)
Cheers!
Rob
Re: Ring Duration
Rob,
Thanks for quick reply.
What is the setup required? CSS and number for CFNA or one of them ?
Re: Ring Duration
Hey Gary,
No worries my friend! Yes, the Forward No Answer configuration requires a Directory Number entry (or Voicemail checkbox if using VM) and an applicable CSS, usually something restrictive that cannot reach off-net.
Cheers!
Rob
269
