Ring Once on active calls CUCM 9.1
Amine Nouasri
Level 3
Level 3
Does anyone have access to CUCM 9.1 to confirm if ring once on active calls works in CUCM 9.1?
I have used this feature it in the past in CUCM 7 and 8 just fine. This client is saying this doesn't work and it only beeps when a second call comes in.
I appreciate the help.
Hi Amine.
Tested right now on a 7942 and 7965 and works just fine.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Amine.
Carlo
Thanks Carlo for the confirmation!
